need help with cam choice
  • need help with cam choice
    i dont know what cam is best for my engine set up. heres the engine specs
    355ci
    10-1 flat top pistons
    summit racing vortec heads with 170cc runners, 67cc chamber and 1.94 by 1.50 valve with a .520 max lift and 3 angle valve job and 1.6 aluminum roller rockers
    holly vortec stealth ram intake with 24ibs accel injectors and 1000cfm lingenfelter 58mm TB
    headman shorty headers and 3in cat back
    so im looking for the most cam for this set up but with good street manners
    all ideas are welcome. cheaper the better
    HISTORY OF CARS PAST AND PRESANT (none of them were wrecked)
    1989 S10 standard with 350 carb'd, th350, shift kit, shorties, 600cfm, hooker TD's, 3.23 non posi, B&M shifter(sold)
    1991 firebird with t-tops and 3.1L, 700r4, 3.23 non posi, flowmaster cat back, 15ibs injectors, (sold)
    1991 formula with t-tops, WS6, 5.0TPI, WC T5. 3.42 posi. magnaflow cat back, 52mm TB, and hurst billet (sold)
    1994 camaro z28 with t-tops, 5.7LT1, T56, 3.42 posi. CAI, elbow, Airfoil, SFC, STB, pro 5.0, flowmaster cat back. (sold)
    2000 Trans am with t-tops, 5.7LS1, T56, 3.42posi, LT'S, ORY, magnaflow, lid, lingenfelter intake, 3pt SFC, STB, LCA, (current)
    what rockers are you using(1.6 what)
      What trans are you using?
      What type of lifters do you have?
      How high are you willing to rev?
        700r4 with factory stall and shift kit
        i dont know what you mean lifters? im looking for a cam and lifter set
        3.27 posi rearend
        idk i hear the stealthram is good to 6500rpm but i would like to keep 5500-6000 RPM
        its going into a 88 iroc thats already got a tpi system.
          solid, hydraulic, solid roller, hy roller?
            i honestly dont know. what evers best i guess. like i said its for a 88 TPI iroc. so idk if that helps.
              Did you go out and buy another car?
                no but if i get the 88 iroc i plan to get i found a great deal on a stealth ram and heads. but was wondering what cam would go best iwth it.
