LS1 Pacesetter users come on in!
    i had the floor board banging issue also but mine ended up being a bad trans mount, so check that. i actually had the exhaust shop redo my exhaust a couple times before we realized it was just a bad trans mount. all good now and they did go on pretty easily.
      Does anyone have the autozone part number for these, or the murrays one? I just cant find them.
        Creight doesn't have all his stuff on his website. I asked him about the LT1 poly mounts, and then they showed up on his site. PM him, I bet he can get them to you.
          He can but not till after monday, I took this weekend off of work to get some of this done.
            dude they are at autozone they wont be vehicle specific since they dont swap right in.
            its on the energy suspension rack its a block square with 4 humps on them. it says for newer small block chevys
            pm me your phone # and ill call u with the p/n tomorrow when i goto work...
            you gotta drill the rivits out and pry apart the clam shells to get them out and use bolts to get the calm shells to sit fluch together since the mount will appear too big for them but its not.
            also do a poly trans mount while your at it the motor mounts are $25 a piece the trans is like $15
            again it prolly wont show up on their computer for your car since it says gm rwd vehicles
            The LS1 or Go Home Crew
            ASE master certified
              Russ you work at Autozone? And are driving around a C5 Z06?!?!?! Damn, I'm going to go apply tomorrow, lol.
                lol yeah man i even get stock options LMAO!!!!
                its my 2nd job, notin like some sweet discounts
                  Ahh gotcha, lol. Man with a plan
                    Any of you guys have problems with the coating coming off?
                      Those red square ones that say they are 4 new chevys are the ones I needed! Every single place I went to had those and told me they were the wrong ones, wow that REALLY pisses me off. Thanks so much for the info, ill go get a set tomorrow.
                        people dont know that much at auto stores about performance
                        you should do a write up since ur about to do it, since most people dont know what ones they need to make it work.
                        phantom you gotta heat cycle the headers when they are new or it can flake off
                          How many times Russ?
                          The local speed shop here is telling me that they are junk but I haven't heard a bad thing about them and the other forums just rave about them.
                            just initial start up from what ive seen/heard
                              Thanks!
