wondering if heads will help?
  • wondering if heads will help?
    hi. my freinds got a 1991 camaro rs with a 305 carbed motor. he was wondering if adding 2.02 by 1.60 with 67cc chamber heads would help at all?
    thanks
    HISTORY OF CARS PAST AND PRESANT (none of them were wrecked)
    1989 S10 standard with 350 carb'd, th350, shift kit, shorties, 600cfm, hooker TD's, 3.23 non posi, B&M shifter(sold)
    1991 firebird with t-tops and 3.1L, 700r4, 3.23 non posi, flowmaster cat back, 15ibs injectors, (sold)
    1991 formula with t-tops, WS6, 5.0TPI, WC T5. 3.42 posi. magnaflow cat back, 52mm TB, and hurst billet (sold)
    1994 camaro z28 with t-tops, 5.7LT1, T56, 3.42 posi. CAI, elbow, Airfoil, SFC, STB, pro 5.0, flowmaster cat back. (sold)
    2000 Trans am with t-tops, 5.7LS1, T56, 3.42posi, LT'S, ORY, magnaflow, lid, lingenfelter intake, 3pt SFC, STB, LCA, (current)
    2.02 intake valves on a 305 will not work without some mods....plus once you mod it the valve will be shrouded too much.....stick to a 1.94 valve.
      what about on a 350?
        I've got 2.02 intakes 1.60 exhausts on my new heads (355 c.i)
        2015 Silverado
          gain more top end, but lose a lot of low end plus torque.
          Tell him to save some $$ for that 350 swap.
          That's what I did. If I had heads with all the mods I did to my 305, I'd add about 50hp. 305 heads are a bottle neck for sure.
          But I'll save that money for my 350. It will be money well more spent.
          Whats he looking to do? I can suggest a few Ideas. There's a lot of $$ in my little 305 already. But I can at least swap that into my 350.
            They will work fine on a 350.
              might as well get a 350...pretty cheap anyways
                ya, go 350
                Don't wast time with the 305 if you can help it.
                  305 also uses a rather small combustion chamber so most heads will lower compression
