I just finished putting my motor back in my car with the gm 847 cam....and I have no problem with having vacuum issues while braking...It definatley needs a better tune...
LT1 Cam Selection?
id like to go for a ride in your car sometime. I want to know if i shoulda gone biggerOriginally posted by awp944 View PostI just finished putting my motor back in my car with the gm 847 cam....and I have no problem with having vacuum issues while braking...It definatley needs a better tune...
my setup
lt4 hot cam, 1.6 rockers, stock stall, 342 gears, stock heads,intake,injectors, tb. long tubes, 13.8 at milan 4300# with me in it. On street tires and spinning with a 2.1 60ft.12 to 12.4 air ratio he only turned it at 5442 rpm with 283 hp at the wheels with 278 tq. on a 90 deg. day. the more he leaned it the more it lost not a fair test to hot and this was done on a tight mustang dyno. I happy with it the next step would be lt4 heads and intake again old school but will take a beating.
Curious -- Comp Cams recommends the 986-16 in the cc503 instructions, how come you went with 981?Originally posted by LS1Formulation View PostA few years back, I had an LT1 Caprice that I wanted to make fast on a budget. My total budget aside from the purchase of the car was $3500. I bought a pair of stock aluminum LT1 heads (Caprices came stock with iron) and ported them at home. They started out at 208/145 CFM stock, but after porting I had them flowing 243/188 CFM. I bought a Comp CC503 cam, Pro Magnum roller rockers, and a set of Comp 981 springs. With the correct spring seats, those will fit on the stock heads. In addition to that, I bought a 2500 stall converter from Roadrunner converters and a set of 3.73 gears. Also purchased a mail order tune from PCMforless. After installing all of those things, my ET dropped from a 14.82@95 MPH in cool spring weather to a 13.42@104 MPH in 80 degree August weather on street tires. This is in a car that weighed 4770 lbs. with me in it! Your car probably weighs 1100-1200 lbs. less, so you'd be in the mid 12's for sure. Don't even mess with the LT4 hotcam... it's an old tech cam and the Comp CC503 would be just as drivable. I had NO issues with vacuum for my brakes and had an 850 RPM idle.- Brian Meissen
I was goin to go with the 918s2011 Ford Raptor SuperCrew
Dont get comp 918s, get PAC 1218s. Comp 918s used to be the PACs sold under comp's name... and lately Comp changed suppliers and they have been breaking. I would imagine that comp has fixed this issue by now (at least they should have), but still not a chance i would take.-Joel
True that...sorry i should of been clearer do0nt get the comp 918s get the 1218s...better springOriginally posted by JoeliusZ28 View PostDont get comp 918s, get PAC 1218s. Comp 918s used to be the PACs sold under comp's name... and lately Comp changed suppliers and they have been breaking. I would imagine that comp has fixed this issue by now (at least they should have), but still not a chance i would take.2011 Ford Raptor SuperCrew
Totally a mistake on my part... I was looking at a different spring box I had laying around. I DID run 986's on my LT1.
Alright people we need to consider that Brian is a newbie to the V8 World let alone a cammed V8. Althought we know he's responsible this may put him over the edge.
Brain I've always been a follower of the KISS philosophy (Keep It Simple Stupid) With that said the LT4 Hotcam is probably the best choice in regards to cost, powergains, reliability, and the fact that it'll be enough for your limited exoerience.
Sorry bud just looking out for your welfare besides you need to crawl before you can walk.
BTW I should add that a 6spd would make the swap even better.
CraigSemi Retired Street Racer2012 Lava Red Mustang GT 5.0 MT82GONE BUT NOT FORGOTEN
NBM `98 Formula M6 HdTp
1 of 1 Build Date 3/12/98
- Smokey Yunick
Yeah, the LT4 is definitely seems to be the best bang for the buck, but the cc503 sounds so damn good
OK so this is what I have so far -- what else do I need to account for?
COMP Cams 07-503-8
cc503 Cam
http://store.summitracing.com/partde...8&autoview=sku
$259.95
COMP Cams 1305-16
1.6 Roller Rocker Arms at 7/16in Stud Size
http://store.summitracing.com/partde...6&autoview=sku
$285.95
PAC 1218-16
Beehive LS1 Springs
http://www.pacracing.com/Beehive_Spr...Set_of_16.html
$215.00- Brian Meissen
Oh yeah, and I forgot to put in the timing chain... just going to get an LT1 replacement chain.- Brian Meissen
ok
I think we should line them up for Brian to hear, see,and test RIDE, THAT RIGHT TEST RIDE IN. Then take the cars to the track, sorry you guys that spray & charged, motor only to see what they do, not what they say they do. aaaaaaaaaaaaaaaaaaaaaaaaaaah and film it.I won't be last but I know that I won't be first. Then add up what we spent to see if it was worth the money spent. The mistake that I did was not to order the complete package for a lt4 heads, intake, cam, rockers, chain, plus bolts and gasket.Still can get it but not with a gm intake.
