i was looking into completing the top end of my engine with 195cc lt4 heads and the lt4 intake, then with a 58mm t.b. with the lt4 hot cam kit, it claims on summit that it puts you to 410 horsepower.
are these numbers realistic?
of course i need $1500 to do so lol so not anytime soon
lt4 = garbage! u cant expect to go fast puttin stock gm stuff of a vette on ur car
its not stock corvette stuff i already have the cam kit, and the cam has a larger lift then the vette, bigger heads then the vette and idk bout the intake?
The LT4 kit is not worth it IMO. Loyd Elliot is a widely known LT1 builder. His LE1 package should net right around 400 rwhp, and costs $1000. You send him your heads and he ports them and makes a cam for you.
you cant huh? There are people making 500rwhp with stock castings. LT4s and aftermarket heads are only gonna do better. Also the LT4 hotcam has wilder specs than an LT4 cam.
yes i mean the hot cam which i already have that kit in my car, what heads and intake set-up are you running joel?
Advanced Induction 226/234 cam with stock heads milled and slightly pocket ported. (done by a local guy). Intake is bone stock. My goal is 350-375rwhp once i get the tune right.
also remember you can have the biggest cam and heads in the world, does you no good with a restrictive TB and Intake
-Im Ron Burgundy? ----------------------------
i still think lt4 hot cam is garbage just my .2cents and i know theres ppl makin 400rwhp with stock castings(ported) but lt4 heads cost wat it woulda costed to get ur lt1 heads ported to flow better so all im sayin is gm stuff untouched is GARBAGE for the lt1s weather its cams, heads, optis, anything
