Superman09's Exhaust Poll!
  • Superman09's Exhaust Poll!
    Ok i am undecided on this and need to make a decision here REAL soon so help me out and add some input. The choices are in the poll, ORY + Magnaflow catback OR TSP True Duals..... Here are some positives and negatives to each with some information. Also remember, my car has manifolds and turbos so the duals wont be as loud as most NA motors with headers.
    ORY + Magnaflow ($530)
    -Positives
    • Stock location so maximum ground clearance
    • Will have tips out the rear
    • Quiet and Stealthy
    -Negatives
    • Little more restrictive
    • Few more dollars but not much
    TSP True Duals ($430)
    -Positives
    • Great Loud Tone
    • Very free flowing
    • Few dollars cheaper
    -Negatives
    • Less ground clearance
    • Dumped before the axel so no tips
    • More cabin noise
    31
    51.61%
    16
    TSP True Duals
    48.39%
    15
    well the turbos are kinda mufflers so a td setup prolly wont be as loud as a na dumped setup, i know my dumped setup was tolerable
    i made mine tho as well as my new setup and it tucks up nice, i didnt bottom out either last year,
    my car is lowered now tho but haven't yet *knock on wood
    smokeyrider05's td setup hangs as low as the stock exhaust
    The LS1 or Go Home Crew
    ASE master certified
      Duals, its gonna sounds wicked at WOT and its not really much of a sleeper with 12lbs of boost
        Duals.... maybe dummy tips for now ?
          just cump em for now and run them out the back once you get some more $$$$.
            Yeah, dummy tips is kind of a good idea - keeps it sorta stealthy too...
            I don't think it'd be that much more to get the pipes to go all the way back.
            But Duals FTW.
              Magnaflow!
                what about duals over or under the axle
                  cuz im poor for now
                    dbl post
                      if you like to keep your car clean i would stay away from dumped duals
                        hell duals under the axel would be cheap and easy to do, buy the pipe ill help you make it. it'll cost u alot less then 400
                        i made my go over the axel, alot of work
                          duals under the axle are GHETTO! i cant believe how many people do that.
                            Duals w/ dummy tips ftw
                              agreed lol
