Fuel Injectors?
  • Fuel Injectors?
    What injectors would be good...for 150 shot on a 383 stroker 30 lbs?
    Need more info...cam...head work...fuel system...fuel pump specifically...
      depends on how much hp that motor is already maken
      The LS1 or Go Home Crew
      ASE master certified
        Well I am planning on running...Trick flow heads not exactly sure yet on the cam....Prolly a walbro 255 lph
          You really need to get an expected HP output to properly size injectors.
            x2 true dat
              wet or dry kit also makes a difference. A wet kit you can use the stock injectors.
              5th gen Camaro V6 Forums
              http://www.bowtiev6.com
                honestly with a 383 and nitrous im going to say your going to need bigger than 30lb injectors, just get 60lber's and call it a day
                  he has a wet kit and with a wet kit your injectors play no role in this. The nitrous kit adds the extra fuel you need and does not tax your injectors anymore than NA unless you are spraying the wet kit in front of the MAF and the MAF is adding more fuel do to the nitrous going across it. With a wet kit though you want it after the MAF so this does not happen
                    I hope you were just joking with that comment
                      i got/puttin in 42's on my car i got the fast rails and everything also
                        of course i was kidding jeez guys lol
                          Thanks for all the help
