DSC_00235.JPGWanted to share with you guys some new photos of C.O.M.E. Racings top intake plenum setup they have
made with dual 58mm throttle body and intake snorkel.
We need to get this set-up running on some of our 3800's.
Their new dual set-up top and their used lower, complete is 1750.00
Obviously someone will need good fabrications skills as these will have to be modified slightly to fit our cars...
oh yea and from the COME racing website it states it would work with boosted apps too...
"This is the best way to increase torque and power of a stock right though to fully built Ecotec V6. Ideal for strokers and boost applications as well. Comes complete with throttle cable bracket to use OEM factory cable. Machined to accept all original sensors including TPS, Idle air etc. Also inclueds a great cast alloy intake snorkel to allow hookup to stock or aftermarket MAF and air box ducting. The snorkel has additional material cast into it to allow internal boring for much larger intake entry size. This is especially useful for the strokers, boost engines and highly modified 3.8 V6's. Our Twin Throttle body is a tried and proven design with dual 58mm bores made from the best grade of billet aluminium available. The best part actually is that the original factory engine cover fits with only minor modifications so no one needs to know what is lurking under the bonnet. A minimum of 20kw power gain and even more torque low down, mid range as well as up top than a stock intake sutup. It bolts on directly onto your original factory intake runner base in 1/2 an hour or so."
hmm, now to figure out fitments.
Also does the fuel rail come with it?
