o2 sensors
  • o2 sensors
    Since I put lts of my 1995 camaro I havent been able to get it to run just rite. I can tell because I can just feel it. I changed the plugs wires gaskets and have been narrowing it down to I spliced the 02 wires so they where long enough. What can o2s do if they are bad or not getting the correct reading.
    wheres a good place to get sensors and how much am I going to pay. Also I heard that bosch vette sensors come with a long wire so extentions are not needed.
    i used bosch sesnors when i did my header install. no problems whatsoever.
      did you need extentions or where they long enough. How much do they cost
        the extensions came with my longtube headers. Im pretty sure i have a decent ammount of excess wire zip tied however.
          Over on TGO they recommend using only the AC Delco o2s since it has been found that quite often the other brands have different switching points.
            I have heard there was problems with after market
              I believe I have two o2 sensors from my car if you want them?
              1999 Pewter TransAm
              <PaceSetter LTs, Lingenfelter LS6 Intake Manifold, and one little secret... >
              "Spray and Pray"
                Im not sure if the ls1 o2s will work with the LT1
                  I found out they have differant conectors thank you for the offer. Where is the cheapest place to pick these o2s up.
                    Ok I called around and I can eithr get bosch or denso what one is better I havent heard anything about denso but heard some bad things about bosch. I guess this is the next thing I have to try.
                      denso seem to be slightyly more lead resistant
