TBI 305 blowing smoke.
  • TBI 305 blowing smoke.
    Well i have just add to my family a 1992 camaro RS.
    The problem is that is is blowing black smoke at mid-high RPM. I drove it home from ohio saturday. It was smoking when i step on it a lil bit. my dad was saying it was just bad gas or it need a tune up. Also i think i was getting about 13mpg high way if my math is right.
    The next day The car would not start up. SO i was thinking it was just out of gas cuz it was on E. So when I Take off the fliter hoseing I see oil in side of it. Also was not the best looking . So wheni went to start the car to show my dad it would not run. It turned over with one crank easy. So i guess the bad fliter was choking the motor off on the trip giving me bad MPG.
    Well I think that it mite be a blow head gasket or a fried ring. But mlike i said befor the car runs stroung with out a miss, stutter or stall.
    SO what do u think it is?
    What motor will bolt in to the car hard ware with out cutting or welding?
    tbi 350 ,tbi 454, lt1 350, gen 2 chevy 35o, gen 2 chevy 400
    will any 350 bolt in place?
    what will i need?
    1993 Camaro
    th-400
    3.4 to lt1 swap
    stand alone wire harness
    coming soon ( just ask)
    home made S400 frount mount turbo on the way
    397ci 9:1
    Goal 750rwhp+
    what will i need?
    Wow, lots of questions there.
    Black smoke could be a ring going bad...probably not a head gasket. It's also might be a sign of running rich, which would explain the bad mpg. Maybe a bad mass air flow sensor. Pull the plugs and see what they look like...if they're black, you're running too rich...if they're black and oily, you have more than one problem.
    Any SBC will fit without too many issues...BBC, and you have some work ahead of you...quite a bit.
    That, and if you don't reinforce things (i.e. cage, SFCs), a BBC's torque will twist the car badly.
      yea, This is alot in this post I asked. Well if it is rings. i will not waste my time changing them. I would come out better with install a 350ci.
      Well I am on my way over to my dads now so i will give you the update.
      SO what 350ci could i install with out messing with moving the motor mounts?
      gen 2( carb) , lt1, tbi ?
      1993 Camaro
      th-400
      3.4 to lt1 swap
      397ci 9:1
      Goal 750rwhp+
        do a compression test and do a leak down test if its low. if its low compression and if it goes up with the leak down then its the rings.
        Sold!
        www.fquick.com/lozanoa11
        94 Grand Cherokee (sold)
        95 Accord(for sale)
        99 Outback (snow destroyer)
