obd-1 code reader where???
  • obd-1 code reader where???
    i cant seem to find one any where even the autozones i went to only had the years 96+ i have a 93 and a SES light on, please point me to the right direction
    should be able to flash the code out of the SES light by jumpering the top right two pins on the ALDL port. Unless thats TPI cars only.
      paper clip. a and b.
      "Since we are looking at the connector pins, it should be mentioned here that a quick method to see which trouble code or codes are being set in your cars ECM is to jumper the A and B pins of the 12 pin ALDL OBD1 connector with a paper clip. While the car is off, sitting still, turn the ignition key forward while this jumper is in place. Do not start the car. The Service Engine Soon ( SES ) light will flash in a repeating sequence, telling which trouble codes have been set in the ECM. A service manual for your year car will have a chart outlining what each trouble code stands for, or this Trouble Code website can be of help. This paper clip method will tell you the trouble code or codes set in your ECM, but it will not tell you what conditions the trouble code is being set under, or let you clear the trouble codes on the fly, as the ALDL cable and PC setup will."
