How do I dissable the auto headlight feature on my 2002 z28? I'm hoping that is just a fuse.
How do I disable my auto headlights
"ANY car can be an SS but ONLY a Camaro can be a Z28!" Scott S.
"Owning a 9 second import is like coming out of the closet. At first you surprise everyone, but in the end you're still gay!"Tags: None
It's a bit trickier than just a fuse. Helped my buddy out with it the other day.
First, remove the radio. Slide it forward and down enough to gain access behind it. The DRL (Daytime Running Lights) module is back on the right side. Slide it up and out of its holder. There's two connectors (black and blue). Make note of the blue connector. There should be 8 spots (7 used). Be careful now, but take the DRL module apart. The first spot of interest (we'll call it 1) is a black ground wire and wire 3 is a pink wire (hot). The spot inbetween (2) shouldnt have anything in it. What you want to do is solder a wire between 1 and 2 on the circuitboard. This should get the Daytime running lights disabled for ya.1995 Trans Am Firebird. LT1 with 6 Speed manual. cc503 Cam. Pacesetter long tubes with true dual exhaust. LPE CAI. K&N. 4.10 Gears. ZR1 Replica Rims. Comp Cams 1.6 Roller Rockers. Double roller timing chain. BMR Sub Frame connectors. LT4 Knock Mod. Madz28 tune. Pro 5.0 shifter. LS1 Driveshaft. MSD Coil. Sequential Taillights. Custom Interior. Lead foot.
CarDomain
Time Slip: 1/4 -- 12.49 @ 116 MPH
My bad, thought you said daytime running lights not auto lights. I'll leave the other post up there for anyone else who wants it...but as for the automatic lights (I'm assuming your talking about the headlights turning on automatically) there's a photosensor on the dash right above where the DRL module was. You can either get to it by removing the radio or removing the top trim. Basically just replace the sensor with a straight wire. That should get ya all set1995 Trans Am Firebird. LT1 with 6 Speed manual. cc503 Cam. Pacesetter long tubes with true dual exhaust. LPE CAI. K&N. 4.10 Gears. ZR1 Replica Rims. Comp Cams 1.6 Roller Rockers. Double roller timing chain. BMR Sub Frame connectors. LT4 Knock Mod. Madz28 tune. Pro 5.0 shifter. LS1 Driveshaft. MSD Coil. Sequential Taillights. Custom Interior. Lead foot.
CarDomain
Be careful if your car has sat out in the sun and the plastic is brittle. I tried to do this on my V6 and broke 2 pieces off the vent on the dash and when I tried to pry up to pop it off the velcro it started to crack. I had to pull the radio and get to it that way. If you have big hands it's a pain. I installed a resistor in it instead of a piece of wire but I heard the wire works as well since the TA's don't have the auto headlights.
I loved the auto lights on the Caddy and the Grand Prix.- Brian Meissen
Auto headlights suck!!! They come on when you don't want them to and don't come on when they should. I've disabled them on every vehicle I've owned that's had them. I'm not that lazy I can't figure out when I need to turn on or off my own headlights! Unfortunately there are people that do need it!
I love the auto lights on my truck. And the only thing I have to do to disable them is turn the headlight switch from auto to off.
1987 Camaro IROC-Z Pearl White & Black w/ Red Pearl, 355 TPI, A4, 3:42, AirRide,"GOMARO"2017 Silverado Double Cab Z71 Pepperdust Metallic, 5.3, A6, 3:42, "SASYZ71"WMCC Website www.wmcamaro.org
are willing to work and give to those who would not." — Thomas Jefferson
Yeah, same here, Gary.- Brian Meissen
