I would get it up to operating temp. and see how it runs fully warmed up.. I dont know what mods you have that you needed to get a tuned pcm for. But if its nothing too radical it shouldnt hurt it. Just use your best judgement. If you have a cam, headwork, and different injectors then dont do it. Actually, if it was mine I would retry the tuned pcm again. If its still bad I would send it back.
NEED HELP BACKFIRING!
I took it out and it was good for about 10 mins had a few minor pops. I did notice that as soon as I started the car the fans came on for a few minutes. Seems strange to me not sure why they would come on during start up.
Only mods are bolt ons and a 3200 stall converterOriginally posted by zeeman View PostI would get it up to operating temp. and see how it runs fully warmed up.. I dont know what mods you have that you needed to get a tuned pcm for. But if its nothing too radical it shouldnt hurt it. Just use your best judgement. If you have a cam, headwork, and different injectors then dont do it. Actually, if it was mine I would retry the tuned pcm again. If its still bad I would send it back.
There are certain trouble codes that trigger the fans to come on because the PCM isnt sure if things are OK, youll have a check engine light if thats the case.Originally posted by b_radcbr View PostI took it out and it was good for about 10 mins had a few minor pops. I did notice that as soon as I started the car the fans came on for a few minutes. Seems strange to me not sure why they would come on during start up.-Joel
It's strange cause the car has never had a light on. I know the bulb is there at least but it hasn't come on in 4 yearsOriginally posted by JoeliusZ28 View PostThere are certain trouble codes that trigger the fans to come on because the PCM isnt sure if things are OK, youll have a check engine light if thats the case.
Post Whore
- January 14th, 2015
- 1286
- Dan Dalessandro
- 1997 Camaro Z28
- Troy and Port Huron
- Full time student
Does the light come on when you go to start the car? If not bulb is burnt out.sigpic
Post Whore
- 1286
- Dan Dalessandro
- 1997 Camaro Z28
- Full time student
Check to make sure you have cylinder 8 to 8 on optispark, 7 to 7, etc. I messed mine up when I redid mine. Sometimes its the simplest things.sigpic
The codes are gone. However the car doesn't run any better. I had a shop scan it twice no codes, but Oriellys scanned it originally and that's where all the codes came from.Originally posted by zeeman View PostYou need to scan it again. Figure out what the codes are and trace them back. Fans on is an indication of a malfunction. They should show up after driving it.
All the misfiring my car had from plug wires never threw a code on my car. It just ran like dogsh* anytime i gave it any good amount of throttle at a lower rpm.-Joel
That's the only thing that changed. I was in a rush so I didn't have the msd wires on the passenger side so I could take it to the shop for the convertor install. After I got it back it ran great then I fried the wire and replaced all the passenger side wires and it hasn't ran right sinceOriginally posted by JoeliusZ28 View PostAll the misfiring my car had from plug wires never threw a code on my car. It just ran like dogsh* anytime i gave it any good amount of throttle at a lower rpm.
Well thats me making it as bad as possible for demonstration.... I was WOT at low rpm, an auto wouldnt let you do that.-Joel
