If anyone can help share a picture of how their 98-02 PASSENGER headlight assembly lever is connected to the motor it would be really helpful. If you read my last thread, I ended up replacing the main electrical connector and headlight motor on the pass side. The new motor and headlights are both working now, but the headlight physically gets stuck now when opening. When I repositioned the lever, I put it between the two stops you see below. I'm not sure if this is right, but it seems like it. When it gets hung up during opening, it seems to stop itself on the frame where I've put the arrow. I never had this issue on the old one, perhaps I over-tightened everything but and left less space for clearance. If someone can verify this is the correct place for the lever, then I will hack out some of the frame area.
Lever touches top of bottom stop while headlight is up.
I had to manually raise it up to get it like this in the picture. Otherwise it doesn't pass clearance on its own when it hits the farme and stops.
