Today I began my adventure into replacing the pass. side headlight motor. Took everything apart, and before re-assembly I wanted to test all the lighting. Both high/low beams don't work, fog light doesn't work either. Now this is strange because I know the high/low beams were working before I decided to take apart the headlight motor. There was some corrosion in the headlight motor wiring harness connector, two prongs broke off, but I was able to remove the broken prongs from the female endwith pliers, and cleaned it all up with some CRC electrical cleaner and it looked good as new. (guess that could be one possible problem but you think it would be happier now with the new connector and new prongs.) The other confusing part is my DRL/blinker bulb works, and the side marker works. All of my driver side stuff is working so this seems to be pasenger side isolated. Anyone have ideas of what to do here? No way I'm putting it all back together yet til I can get some lights running. Need to drive it to work monday too.
Pictures below
Pictures below
