Vats problems
  • Vats problems
    So my vats has been giving me issues once In a while. So yesterday went to start my 2002 ws6 nothing all lights come on no crank I tried the resistor bypass still nothing. Is it the bcm ? Thanks in advance
    power at the starter? starter crank wire?
      I didint check the starter wires to see of there getting juice . i just checked them out to see if there still good they still look bran new. My security light flashes 3 times so I'm thinking vats and correct me if I'm wrong the vats kills the signal to the starter?
        An another question can I completely tune the vats system out? I've heard yes and no on it and can I just put a push button start on it. Sorry I'm not used to this computer crap
          I put a push button start in when I started having VATS problems. I still have to have the key to put it in "run," but as long as I don't try to start it with the key it runs. No tuning or anything. I haven't had a single problem since.
          Check out my 'bird: http://www.mifbody.com/vbulletin/sho...256#post325256
            You need one of these:
            http://www.ebay.com/itm/GM-VATS-or-P...3f41bd&vxp=mtr
            I have a write up I can send you if you want.
            Had all kinds of Vats problems with a previous car. Put that in...never messed with it again.
              yes
                Thanks . Ill keep all that in mind when it dose go out. I don't know why my security light would flash and stay on, I pulled the starter and tested it dead slapped a new one in fired right up.
                  Yes, and I've done it.
                  Used to own a Firebird.
