I may have to remove the valve covers and start it cold and adjust one or two rockers that make noise until its warm. Otherwise this appears to have helped my problem.
While it is much improved there was still a miss around 1800 -2000 rpms that I just couldnt do anything about. So this morning, I put the laptop in the car and started her up. I used a small flat blade screwdriver as a wedge to adjust the rpms into a range that highlighted the miss. I then unplugged the injectors one at a time while listening to try and identify the cylinder that is misfiring. 5, and 2, seemed to cause the least disruption to its running while unplugged. but when I plugged 2 back in there was an improvement in the running that was immediately apparent . Things have certainly smoothed out. No more rattling console @ w.o.t. I dont know if there was just a bad connection or if it was plugged and the act of plugging it back in unplugged it. I am just happy its running correctly.
Never mind: it went back to running like poop shortly after. I had to take a day or so to cool off.
