Hey everyone, just a quick question...On a 94 camaro that came with the Delco CD player, can anyone tell me what color the power wires are? Are they just Yellow, Orange and Red or???? Reason i ask is that i am re installing the factory plugs for the Delco stereo so i can use the factory stereo again. I wired up the Yellow to Yellow, the Red to Red and a Grey to Grey. When i try to power the stereo on, all i get is the convenience light where the CD goes in. If i press either the HR or MN buttons, the clock will come on for about 3 or 4 seconds and go off. The actual unit its self is not powering up. When i turn the key on there is no noise or anything. It will eject a CD and you can put one in it but it wont play. Anyone have any ideas?.....
Help with factory stereo wiring....
Thanks,
Stephen
1994 Chevrolet Camaro Car Radio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: Pink
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 6 1/2″ Speakers
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: 6 1/2″ Speakers
Car Audio Rear Speakers Location: Side Panels
Left Rear Speaker Positive Wire (+): Yellow
Left Rear Speaker Negative Wire (-): Brown
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Bluesigpic
1996 Base Model
+2 cylinder mod
Thank you good sir, i appreciate it. Thats exactly how i hooked it up but all i can get is the button lights to come on when its plugged in????? Any ideas? I know its a good Delco, i seen it work....im confused lol....Originally posted by jderry View Post1994 Chevrolet Camaro Car Radio Wiring Diagram
Right Rear Speaker Negative Wire (-): Light BlueThanks,
Stephen
