Hey everyone, just a quick question...so far on my 94 i have discovered that it is actually (VIN) coded for the v6 but has had a lt-1 and ecu swap, so i guess its considered a conversion i think?? Anyways, it has an aftermarket keyless entry system that apparently has never been completely hooked up. My question is=====> Since my car has had a new LT-1 and ECU installed and still has the factory ignition key and VAT module, what would my options be in order to remove the aftermarket keyless entry and use the factory keyless options? In other words, what do i need to change out, purchase or do in order to put my car back to factory and be able to use the factory keyless, etc features? I am sure that i will have to purchase a new factory FOB or remote, but what else do i need to do to get it back to factory? Also, i have checked my RPO codes and my car does have the factory keyless module under the passenger side kick panel....
Thanks Everyone for your Help
