OK I am not the most electrical savy person in the world. figured why not swap because I have a set from the 94.
Searched on ls1tech and found a common ways people did this.
So here is what I did. starting with the passenger side
Located the brake bulb. Found the little grommet labled B. Pulled grommet and stuck in some automotive wire. Jammed grommet back in and electrical taped it to keep it from falling out.
Ran the wire to the turn signal and tapped into brown wire labeled B
Tested the lights, had no reverse working, checked bulb and fuses and still nothing.
Reverse worked prior to LT1 tails
