1995 formula m6 vats issue?
  • 1995 formula m6 vats issue?
    So i picked up a 95 formula 6 speed.
    And i cant figure out why it will only sometimes
    Try and start with the key. I can always start it
    By dumping the clutch.
    So ive noticed my security light will stay on while
    Driving. Ive also noticed that while i try to crank it
    The security light will continuously flash.
    And on the rare case it goes out. My starter will click
    For a brief moment likey battery is too low to start it
    And it will make the sec light flash again. And it wont
    Start. But i can always get it to start with a push and
    Dump.
    And another thing.
    I put my optima red top in it from my z28 and it acts
    Like the battery is dead. Very low voltage reading on the
    Cluster. Yet i know this battery is good because it starts
    My z28 everyday... Something is taking alot of juice and i dont know where
    To start. Could it be the vats system?
    Think the next time its running im going to pull the battery term and
    See if it stalls. If so its the alt causing the drain issues. (i hope)
    Should i bypass the vats system?
    Pulling a wire off the battery while engine is running is a terrible idea for anything with a ECM
      I havent done it yet. So i probably wont. When the car is
      Running it charges at 14 volts. So i think the alt is good.
      But im just going to bypass the vats and see where that gets me
      The chip in the key has little prongs and theyre worn flat.
        OK so I read the ohms on my key I set the meter to 20k and it
        Gave me a reading of 0.88 and from the tables I have (I'll list them below)
        It looks like I have key #5 0.887
        #1= 0.403
        #2= 0.523
        #3= 0.681
        #4= 0.887
        #5= 1.130
        #6= 1.470
        #7= 1.870
        #8= 2.370
        #9= 3.010
        #10= 3.740
        #11= 4.750
        #12= 6.040
        #13= 7.500
        #14= 9.530
        #15= 11.800
        So correction it looks like I have #4 not 5.
        Or am I totally wrong? Whatever one you think it is let me know.
        And I'll try it out...
          re
          I also picked up 1/4watt 5% tolerance resistors. Are these
          The right ones??
            No one knows???
