Ok guys, although I aced circuit analysis, I have no clue what to do about this one. Let me give all of the details: I replaced my alternator about 2 years ago, and not too long after that, I began to experience a very inconsistent, nonfrequent voltage problem. Most of the time, it was fine (at about 14-16 volts I believe). Other times, it would drop to 8-10 volts. It had started becoming more and more frequent as time went on, and now it's constant. A few days ago, it had been on and off with the voltage drop 15 then 8, then back up and down again. All of a sudden, my check gauges light came on, and the voltage has been between 8 and 10 volts. I had advance auto do an electrical diagnostics test and everything checked out. So, does anyone have any ideas? My only thought is a loose wire somewhere, but I haven't noticed one...
LOW VOLTAGE PROBLEM
Regular
- March 31st, 2009
- 196
- Doug M
- 1996 3800 Camaro
- Plainwell, MI
- Mechanical Engineering Student
Unfortunately I've got nothing to help, but I wouldn't trust Autozone or O'Reilly or any of them. I had my alternator tested at least 5 times while I was having problems and everyone said "Nope, checks out OK." Until I was driving to work and the "Check Gauges" light came on. Replaced the alternator and hey wouldn't you know, problem fixed.- Brian Meissen
aka "Plum Nuts"
- June 4th, 2008
- 5699
- Larry Meissen
- Macomb, Michigan
- Realtor
Could be loose or bad ground connection. Measure voltage at battery terminals then from ground to alternator terminal they should be the same. 13.5 volts engine not running. Batterys can short out intermitantly, diodes in regulator (internal in alternator) can short intermitantly. Measure from + terminal of bat. to various grds, ie; engine block, body parts, all should be the same.sigpic
Regular
- March 31st, 2009
- 196
- Doug M
- 1996 3800 Camaro
- Plainwell, MI
Regular
- March 31st, 2009
- 196
- Doug M
- 1996 3800 Camaro
- Plainwell, MI
Make sure there is no draw on the system when the key is off and after the modules go to sleep. The charging system can be tested with the engine running with a tester like a Sun Vat 40.Originally posted by Doug96CamaroRS View PostCar didnt start this morning... I'm guessing the alternator?
Regular
- March 31st, 2009
- 196
- Doug M
- 1996 3800 Camaro
- Plainwell, MI
Got it running. The wire that goes into a one-wire harness that plugs into the alternator was broken. lol
That was going to be my first suggestions. Happened on my trans am.Originally posted by Doug96CamaroRS View PostGot it running. The wire that goes into a one-wire harness that plugs into the alternator was broken. lol98 z28, m6, monster clutch, eibach pro kit, custom twin turbo setup, 317 heads, z06 valve springs, arp rod bolts, 512rwhp at 10lbs. cobra eater
