What are these connectors under the console
  • What are these connectors under the console
    Went on a search for my shifter light wire (which I finally found) but I also found these two connectors not connected to anything. The orange/black comes from the right side of the console, while the other longer one comes out of the wire loom on the rear left side (by the airbag thing). Anyone have any ideas?
    ~Phil
    the 4 sided one is a power outlet plug
    i forge what the other is
      I think the other one is the seatbelt wire or the parking brake light wire.
        what would a seatbelt wire even do? I think that's what it is based on the spec diagram.
        ~Phil
          I think one of those might be the traction control? Does your car have the TCS switch? If so then ignore then ignore what I just said lol
          Adding power makes you faster on the straights. Subtracting weight makes you faster everywhere.
          For six days work may be done, but on the seventh day, you shall have a track day, a Sabbath of competing, to time the FIREBIRD; whoever does any work on it shall be put in last place.
            yeah I have the TCS plugged in by the cig lighter.. the orange/black one is closer to the emergency brake and the other by the air bag module thing which we now think is a seatbelt connector, whatever that means.
            I don't have any seatbelt lights on my dashboard or anything.
            ~Phil
              Thats probably because its not plugged in, lol
                ~Phil
