taylor 409 race wire is 10.4mm not sure about kits but maybe it could help your search.can you run LT1 wires?just ran towards back instead of front?
I want to make my own.. I've bought 2 sets that were supposed to be made for relocation setups, and I end up running wires all over the place cause they're 8 feet long..
any way to get end that boot will move and take crimped piece apart carefully so you can reuse?so you can cut to length.(maybe try on old wires if still laying around)or if you get just the crimp on pieces somehow(not sure what the connecter is called)
I guess when I park it, I will work on taking the old wires apart.. I doubt they can be reused.. Worse case, I make some custom length 8 MM's...
I would just buy a set of the LT1 Taylor 8mm. There is no need for 10.4 mm wires in this case IMHO. I have had the same set of Taylor 8mm on my car for 8 years and have had no problems. I have found that its all in how well you crimp the ends. Good luck in what ever you pick up Larry. Eric L
1997 Camaro SS #2819 M6, Red, 3.42, 1 of 27, Ttops, BBK shorty headers, Flowmaster cat back, 1.6 rr, LT4 valve springs, ASAM CAI, Centerforce clutch, runs 12s, breaks 10 bolts. http://s602.photobucket.com/albums/t...20Camaro%20SS/
They'll be 8 MM... I just want to make my own so I can make it look nicer under the hood... My friend has the vice crimper, so figure I'll measure them out this winter and crimp the ends on at his place while drinking beer..
