Going to try Optima again...
  • Going to try Optima again...
    Gonna give Optima another shot. Want a Gel cel for my battery relocation I am going to do this winter.. I didn't have any luck with the yellow top, just buying a red top this time. Wish me luck! plus i get 20% off....
    Boooo!!!
      Originally posted by ITSSLOW View Post
      Boooo!!!
      I know. I am still debating. Are there any other gel cels out there?
        i had a red top when they first come out never had a problem with it.
          I was going to get another duralast gold, but for 40 bucks more I can get a red top.
            I went through 2 red tops with my sonoma in less than 3 years. The same Duralast (std., not gold) in my car Explorer with no issues.
              Yeah, crap.. I already know Optima sucks too...
                Oh, sorry. I didn't even put the timeframe in. That standard duralast has been going since 2005 without any issues. I just wish it wasn't red. When I pop the hood to check the fluids it looks like Christmas. Hell, the factory Motorcraft only lasted just about 3 years.
                  I was just reading reviews. I'll be getting another Duralast.. No way am I getting another yellowtop..
                  OPTIMA RedTop™ batteries are designed for short term high current applications such as starting engines, and short high amp uses of a winch motor. They do not like to be "deep cycled" (like ALL automotive starter batteries) however the Red Top battery with its SpiralCell Lead Plate Technology, will suffer much less from the occasional deep discharge such as leaving your lights on or winching until the battery dies. Because of the fact that SpiralCell technology can store more energy for a given sized battery these types of battery are ideal for use in offroad vehicles where reduced weight is important because a much larger "conventional" battery would need to be used in place of an OPTIMA to give the same starting current capability.
                  They are not specifically designed as "deep-cycle" batteries, for constant deep discharge/recharge cycles you will need to look at the YellowTop Optima batteries.
                  This sounds like my yellow top..
                  Worst Battery EVER!
                  I purchased this battery for my G35 coupe. I have used it for 2 months to replace the OEM battery. OEM battery lasted 4 years, but opitma Red Top is having trouble turning on after only 2 months. The cells cannot hold a charge and the battery sounds weak when I lock the car doors. WORST EVER! Do not recommend!
                    My grand prix has the original AC Delco and its still running strong, at 7 or 8 years old. Camaro has a an Interstate I think.
                    Anything but an optima
                    Are you totally stoaked to get your car back?
                      I'm getting there.. Leaving for Missouri next Thursday, hoping I get it back when I get back the following week.. We'll see. Going down there today to see if anything else has been done over the last couple days..
                        Yeah Optima FTL, I'd run a duralast, thats whats keeping the thirdgen alive.
                          Might spend the dough on a Sears Platinum..
                          The P-1 Platinum Automotive Battery from DieHard features 135 minutes of reserve capacity and 880 cold cranking amps. Its corrosion-resistant high quality tin-coated brass terminals provide reliable starting power in all weather conditions. Its rugged, military-grade construction features robust casing for increased compression and offers superior vibration resistance, making it ideal for off-road applications.
                          • Longer off-season storage time - show cars & classic cars
                          • Ideal for luxury vehicles with multiple electronic accessories
                          • Plates made of 99.99% pure virgin lead
                          • High purity grade acid held safely in place by glass mats; non-spillable design
                          • Absorbed Glass Mat construction provides mounting flexibility & guarantees longer service life
                          • 4-Year Free Replacement; 100-Month Prorated Limited Warranty
                            Original Red Tops are a very nice battery...don't know what's happened to their quality....sucks.
                            FWIW...deep cycle batteries should not be used in a standard car application. Deep cycle bateries are designed to be fully charged then run extremely low before they are recharged...like in drag cars without an alternator or fishing boats
                              Always wondered what deep cycle was..
