battery move...
  • battery move...
    all right gents i want to move my battery to the back on the car is there a place where i can order a kit to do so or should i just wing it.
    Both Summit racing and JEGS sells universal trunk mount kits (cables, box, straps, hold downs, etc.) - from personal experiance the plastic box they provide doesn't fit well in our rear finder area. I believe BMR sells a metal tray to hang off the frame rail back there thats a much better fit and looks a helluva lot better.
    Word of advise, since your going to be running a lot longer positive cable from the battery this way, go with a 1-0 gauge cable.
      lead acid requires a sealed box.
      if you plan on going to the strip you are required to have a external kill switch also
        not the strip but autocrossing
          thanks man i well check it out
            thanks guys found the one from bmr and is on the way to my house
              let us know how it goes, Im thinking of doing the same thing, what size cable did you decide to go with?
                i well prob go with 1-0 gauge just to play it safe
