Plug Wires
  • Plug Wires
    Has anyone ever tried running these or know anyone who has? 10.2mm wires for this price is really good.
    http://cgi.ebay.com/ebaymotors/SPARK...Q5fAccessories
    Here's a sig with my old ride: (Everyone else has a cool sig I had to do something!)
    some biggg wire there
    my dad uses taylor 10.4mm i think
    1996 Base Model
    +2 cylinder mod
      I guess the question is: do you have headers? then it might be well to run them over the top if they are long enough. if not the under but have to tie them up so they are out of the way.
        Honestly, 10.2 is way overkill.
          Yep...the 89 has the Taylor 10.4 Thundervolts as well...very pleased with them.
          From Ecklers:
          http://www.ecklers.com/product.asp?p...0&dept_id=1283
            Ok I will just run the 8mm wires then thanx. I might have found headers on CL goint to call the guy and see if he will seperate the headers from the engine, in the pic they arent even bolted on!
              7mm AC Delcos are all you need grasshopper
                I had 11mm on my turbo car. It's more for insulation mostly. I run 8.5's on my Camaro right now.
                Vision is a good company even though they're an Ebay brand. I've had good luck with them.
                Joe - ATM SQUAD
                At the shop, watching them build my car.
                  Has anyone put an ohm meter to these wires yet? They say low impedence, but Accel 8.5s did too and I could feel a difference between them and the mallory pro sidewinders on the '79.
