New Distributor/Coil set up - Any ideas?
  • New Distributor/Coil set up - Any ideas?
    My distributor(well i think) my distributor has gone. the cars not sparking, so my plan is to replace the coil and the distributor (the wires and plugs are new. plugs are brand new, wires have about 3000 on em) so the coil and distributor are next, barring any unforeseen problems. so i was wondering if anybody had recommendations/warnings on what set up to use. id love to go msd but it totals out around 750 with the cap and rotor, and while i love the car i cant imagine that an msd is truely that much better then say an accel. any thoughts, and suggestions are greatly appreciated. THANKS
    sigpic1994 Z28 Camaro-5.7l 6spd man
    K&N Cold Air, Granatelli MAF, Vortec 90* Inlet Elbow, BBK 52MM TB, Edelbrock Intake Manifold, Taylor 9.5mm wires, BBK Headers, Magnaflow Y-pipe, Magnaflow High Flow Cat, Magnaflow Catback System
    Go AC Delco, I've never heard good enough reviews of the MSD stuff to warrant the higher price.
      Where are getting a price of 750 for the MSD? Its 499.99 from me, includes cap and rotor. I have sold a ton of these this year without anyone contacting me with a problem. But nobody that I know of has these in stock now, they are on national back-order without a ETA from MSD.
      The only other one I have in stock is a Accel unit, 269.99
      http://cs3automotive.com/index.php?a=PROD:1255
      EDIT: Does the 750 you looking at include new coils?
      2011 Camaro SS
      1999 Camaro SS #4153
      1986 Monte Carlo SS
      1969 Camaro - 427 Rat
        MSD Coil - 41.99 shipped
        http://cs3automotive.com/index.php?a=PROD:1777
        2011 Camaro SS
        1986 Monte Carlo SS
          yeah i dont know where i got that price i saw it in one of my performance catalogs i guess(JEGS, SUMMIT, CLASSIC INDUSTRIES ECKLERS). i dont know i see that it is 499 with the cap and rotor. and 40-43 for the coil. csmith4153 what do you recommend for a coil. and have you heard enough abotu the MSD to warrant the price. and meissen where did you find an ac delco the only ac delco ive found is jsut the cap and rotor.
            If u already lookin to spend 750 u miswell spend a little bit more and eliminate the opti all together
            Lsx swapped
              well it would actually totall around 600. and i never really considered eliminating the opti, i had read about it, but not really given it much thought. did you replace yours. if so where did you get it, and about how much was it? im open to suggestions.
                I no longer have an opti. I use a ls1 pcm with a cam sensor in place of the opti. All parts total cost around 900 or so. But alot of time and labor. Not to mention u need a good dyno tune afterwards.
                Lsx swapped
                  All of the "performance" coils are within a few bucks of each other. But I have like all of the MSD stuff I have used in my personal cars.
                  2011 Camaro SS
                  1986 Monte Carlo SS
                    ill probably jsut swap the opti. since its summer now, if the opti went in the fall id probably do the ls1 swap since i cant drive the car in the winter. but since i only have time to work on the car after work i would rather not take on such a big, long project right now.
                    im probably jsut gunna put in the distributor and coil for now maybe the ignition box later. now i jsut want my car back. and i might not even get the msd opti jsut because of time. ive only found it online, and it wont ship for 4+ weeks.and that is most of my summer and i would liek to have the car for the summer
                      Yea, the MSD are on back-order, no one has them in stock. I wouldnt trust that 4 week to be in stock either. The last I heard is the MSD cant even tell us when they will have more.
                      I do have the Accel in stock
                      2011 Camaro SS
                      1986 Monte Carlo SS
                        yeah thats what i figured. but its all good for right now, bc a buddy of mine had a new coil that he bought for a 350 and never used it. he said to swap the coil(hes a mechanic). we swapped the coil and strong start. so i'm gunna leave the opti alone for now. hopefully until november then ill have a lil extra cash and a ton of time to play with the f***er lol. it still doesnt start tho, so im going to my fuel system over the weekend, since i have spark and air i need fuel to run so that must be my problem. if anybody has suggestions on a pump or fuel injectors, i might need thos next. so thanks for the help on the ignition stuff guys. ill take it all into consideration in the winter when im diggin into her
                          I wouldn't waste your time on an MSD. I've blown 2 in two seasons. My MSD will be up for sale in a week or so.
                          Joe - ATM SQUAD
                            Make sure ur oil pressure with is workin first. The fuel put gets a first prime on key on but doesnt stay on constant until it senses oil pressure. Its a pain to do a pump in these cars. Unless u cut a hole in the top
                            Lsx swapped
                              You also run over 7000 RPM and that's not advisable either.
                              I have a MSD cap and rotor along with the 383 I just built for Old Fart on this board and never had a problem.
                              We both have MSD coils and I have a MSD 6AL ignition and have had no problems with and of the products from MSD.
                              AC Delcos have standard contacts on the inside where as MSD (not sure about the others) have brass/copper contacts as well as the rotor that will last longer and conduct better spark.
                              There are 2 ways you can do the ignition on our cars:
                              1. go with an LS1 pcm and a trigger system
                              2. go with a LTCC system that keeps the optical sensor in the opti for signal and gives you the LS coils.
                              Both of these systems ar with in a 100 of so of each other for price.
