Key VAT code
  • Key VAT code
    I want to get another set of keys made for my Z28. So how do I find the correct VAT code, for the ignition key. Which I assume is a resistor valve. Is that a code that's on the placard on the glove box door.
    Thanks, Rick
    Never complain,Never explain.
    Member Eastern Michigan Camaro Club
    Use a multimeter to measure the resistance going across the chip.
      THANKS, That's easy enough. I was looking through Ecklers catalog and they list blank keys with different VAT codes. How do I determine which one is right for my car?
      Rick
        Rick
        Here ya go...
        http://www.vatskey.com/vats/lostvatskey.htm
          http://www.thirdgen.org/vats_passkey_system
            Thanks guys! I appreciate the info!!
            Rick
              you can go to shbox.com and there is a proceedure to measure and bypass vats. then you can buy a regular car key.
                or you can just go to a dealer and they look up your vin and then if its wrong atleast you have them to fall back on
                Sold!
                www.fquick.com/lozanoa11
                94 Grand Cherokee (sold)
                95 Accord(for sale)
                99 Outback (snow destroyer)
                  Dealer can look it up, also, if you take it to the home depot(by us atleast) they can measure it and make your new key to match the original.
