Hooking up Electric fan.....??????
  • Hooking up Electric fan.....??????
    OK..... the fan always come as pullers....
    ( This is on my '55 )
    Using mine in front of radiator as a Pusher ,so I already turned the motor - blade assembly around...
    Now when you do that it says to reverse the wires also...
    there are two ,one Blue & one Black.....
    That makes the Black one the hot wire then ,and the Blue ground ??????
    Just wanna make sure ...ANYONE !!
    **** FEAR THIS ! ***
    that would make sense to me. i would just temp them in and see if it works.
      Yeah, hooking the wires up backwards will make the fan spin backwards.
        Yep. It's a DC motor so swapping the two wires will make it reverse.
          Yep ...got it figured out.
          Just waiting for a carbon fiber guarded toggle switch to get here from Hong Kong(can u believe that ) ..
          gonna put it in the dash so if I wanna turn it off or on I can....
