lt1 blinkers not working
  • lt1 blinkers not working
    trying to help a friend. ive replaced blinker switchs before before and im thinking its the same thing but im sure someone here knows. turn the blinkers on and they just light up. he did replace all burnt bulbs. thanks
    Did he replace the bulbs even if they lit up? Cause they can still light up but they wont blink
      did you try the flasher if4th gens have them that is
      Sold!
      www.fquick.com/lozanoa11
      94 Grand Cherokee (sold)
      95 Accord(for sale)
      99 Outback (snow destroyer)
        do they blink with the hazards on?
          Yes, They do blink with te hazards
            i think he only replaced the ones burnt out
              I'd replace all of them. If they stay on solid, theoretically it's the bulbs. But I will admit that I had issues on my car and it turned out to be the carPC apparentlly because as soon as I pulled the carPC out it started working fine
                should have a turn signal flasher and a hazard flasher.
                The flasher is probably bad
                  Thanks, I will try a new one tomorrow.
                    Usually, what will happen if there is a burnt bulb, is the indicator will remain lit in the dash (just the way these things are wired). Anyway, if the LT is the same as the 6, the flasher is in the knee bolster. Odds are, that'll probably be the prob. They got a solid state flasher at Autozone for like $10.
                      The bulbs have 2 filiments, one that lights up for flashing, and one for running lights. If it lights up for running but doenst flash its probably the bulb. Id try that before the flasher, bulbs are cheaper.
                      But the flasher is in the knee bolster area, on the left I think?
                        ended up being the flasher which i thought but couldnt find for some reason. all is good. now i just got to get him to get that thing ready for the meet and greet. thanks guys
                          I put a new flasher in and blinkers work fine, THANKS.
                            I bet it was just low on Blinker Fluid
                            Can't believe nobody beat me to that one
                            '73 Z28 388 Stroker, M22 Rockcrusher 4 speed
                            WMCC Photographer and owner of Redline Photography
                            You are only young once but you can be immature your whole life!!!
                              ...B already beat me with the boy scout joke earlier. I took my toys and went to another playground. LOL!
                              By the way, did you end up with the electronic one? The say that those don't wear out, so you won't have to deal with it for a VERY long time. From the looks of the isides, it's all solid state.
