Do you need the tech 2?
  • Do you need the tech 2?
    Do I need to activate the abs to bleed my rear brakes with the tech 2?
    I cant seem to get anything out of my bleeders
    u kno u can bleed the brakes at each wheel right?
      im shure he knows that but some cars you have to cycle the abs to blead the brakes. But you shouldent have to i did it in my 98 without a scanner. weather i did it the right way or not im not shure but make shure the master cylinder is full.
      how are you bleading them? a power bleader might work better
      Sold!
      www.fquick.com/lozanoa11
      94 Grand Cherokee (sold)
      95 Accord(for sale)
      99 Outback (snow destroyer)
        u dont HAVE to have one, but if someone pushes the brake same thing (I would assume)
        99 Grand Prix GT - Winter Ride
        ___M&R Electronics ___
        .MECP & ASE Certified.
          i really dont know if he knows that i know the kid personally
            make sure that the bleeder screws are clear of any gunk, They can get clogged which will cause nothing to come out.
            I am fairly certian that you have to have a tech 2 or at least a scan tool with the right card to acess gm abs systems. We have a tech 2 at work so anytime we have a gm vehicle in I just use it anyway.
            And yes sometimes you have to bleed the abs system on a car to get out all the air in the brakes. But most of the time just bleeding them at each wheel works fine, Is the brake system a diagonal one? if so bleed the system diagnonally (right front then left rear, left front then right rear)
              lmao thanks for the obvious shizzy...... anyways yea i used a pressure bleeder at my shop....we do have a scanner but it cant acess the abs..I have also tried having someone press down on the pedal and still cant get anything!
                aaron i need my engine stand tonyte or tm even if u gotta just drop it off in my back yard my buddy who i got it from needs it asap
                  lol where you about to be at in like 20 minutes
                    my house
