I'm having a problem with my car starting. It won't start when cold until the oil pressure builds up enough to energize the fuel pump.
Last year I was having this same issue and I had the fuel pump replaced. This year my fuel pump relay wouldn't prime so I replaced it but it still doesn't prime with the new relay but the relay clicks when the ignition is turned on. I also put the old relay back on and it also clicks so I'm not sure if my relay was even bad.
Any suggestions on this one.
