Looks like it's time to pull the intake and swap out knock sensors, threw the low voltage code again on #2...
Figure while the intake is off I should do heads too..
How do I go about determining the best heads for my application? I have no idea, am I best off just calling some reputable people who deal with heads??
Going to try and ride this out till winter, low voltage shouldn't hurt anything, just hate seeing that dam SES light on.. Had it reset today and hasn't come back on.. I also read to check the PCM pins and make sure none came loose as this could cause the problem too, so will be checking that out before I drive it again..
Anyone know of any issues that could be caused should I drive it this way till winter? I know it isn't a motor issue, def a sensor issue..
