Ignition Module grease
  • Ignition Module grease
    I posted this over on ThirdGen.org and I figured I would through it out here and see what you guys think.
    I have a remote coil ignition module that is bad and I have a spare that I am trying to install. The problem is I cant
    seem to find what the correct grease is. Someone said to use CPU thermal grease which seems to
    make sense since it is supposed to help transfer heat out of the Module. Any ideas? Thanks
    Shawn
    I think Permatex makes some.
      sounds like an question for James!
        die electric grease
          Shawn
          you should be able to find some thermal grease at a parts store. cpu stuff would probably do the trick, but it might not hold up so well underhood.
            Thanks for the info. The stuff they gave me was called dielectric connector protector. It just didnt sound right but it was dielectric so I used it and I haven't had any problems yet. Thanks for the help.
