I think my blinker/wiper/brights control arm needs to be replaced. My brights don't work at all, not even a click. Blinkers are fine and as for my wipers, half the settings don't work. So I'm wondering if I need to replace the whole thing or can it be repaired? Also how hard is it to replace? looks like it be a *****.
Wiper arm/blinker control arm
\,,/>_<\,,/
- May 11th, 2006
- 10130
- Mark
- 2023 Malibu, 2022 Explorer
- Winston Salem, NC
Its called a multi-function switch. Just get a new one. They arn't that expensive.
There is no quick fix since it is all electrical.
unfortunately my system only goes back to 98 - hope this helps
Document ID# 450307
1998 Pontiac Firebird
Multifunction Lever Replacement
Removal ProcedureInstallation Procedure
Wiper Switch
GM Firebird 1982-1992 Repair Guide
REMOVAL & INSTALLATION
The wiper switch is part of the multi-function lever, located on the steering wheel column.- Disconnect the electrical connector of the multi-function lever, located under the instrument panel.
- Remove the protective cover from the wire.
- Grasp the lever firmly, twist and pull (the tang on the lever must align with the socket) the lever straight out.
- Pull the wire through the steering column.
- Slide a music wire tool through the steering column and connect the lever wire to the tool wire; pull the wire through the steering column.
- Push the control lever into the spring loaded socket (be sure to align the tang).
- Install the protective cover to the wire.
- Connect the electrical connector of the multi-function lever
\,,/>_<\,,/
- May 11th, 2006
- 10130
- Mark
- Winston Salem, NC
\,,/>_<\,,/
- May 11th, 2006
- 10130
- Mark
- Winston Salem, NC
Hey Todd you wouldn't happen to have a diagram like the 1 you posted would you. For some reason I have a feeling mine's more like the 98.
Same with Brenna's 94 camaro. Anyone know a place and part number that carries them?Originally posted by JAdair View PostDoh mine is the same way the brights dont work at all like Mark said it doesnt even click to turn them on
Its been like that sence i got the car blah stupid cars lol2005 Yamaha R6
should be #01995963Originally posted by ITSSLOW View PostSame with Brenna's 94 camaro. Anyone know a place and part number that carries them?
confused???Originally posted by SouLTeRRoR View PostHey Todd you wouldn't happen to have a diagram like the 1 you posted would you. For some reason I have a feeling mine's more like the 98.
do you mean like the one i posted for the 98?
if so sorry thats all i have
