As many of you know, i recently did an OTVC plug wire kit on my car, and now im on gremlin number 2.
the issue im having is a stumble from 1-2k rpms, under load (half throttle or more). It is also mostly in first and second gear. the car seems to 'hiccup' and mildly buck the drivetrain. If i hold it under load, it will usually buck continually until it gets out of the lower RPMs. It almost seems like something a car would normally do under heavy throttle at low RPMs, but the thing is... it didnt do it before the new wires were installed.
The car still pulls hard as hell, but its definitely weaker on holeshots. It doesnt want to turn the tires from a slow roll like it used to. (low RPM holeshots are the LT1s specialty) The way it is right now i am 99% sure it would sputter on me coming off the line at the drag strip.
it doesnt seem like a plug wire issue but it kind of has to be... so im looking for advice on what to do next. Some people have told me i should stick to factory wires, so im debating trying that.
heh...
heh...
