coil pack question
  • coil pack question
    well my car is running a lil rough and it has every symptom of having a bad coil pack how do i check which ones bad without messing anything up?
    thanks!
    nick
    I had a bad coil pack take it to someone who can test it and tell u.
      explain rough...
        Do what I did, After replacing the plugs and wires only to still have it missing. I took a spark plug and hooked the wire to it. Started car, see if the plug is sparking. Do that till you checked them all.
        2011 Camaro SS
        1999 Camaro SS #4153
        1986 Monte Carlo SS
        1969 Camaro - 427 Rat
          well it idles fine but the service engine soon light pops on and off lack of power doesnt smoke or have any signs of a blown head gasket but when u drive it runs rough but not really bad now this coil p[ack set is off of my old motor thats been sitting for over a year and a half without running...so the plug test works huh ?
            Thats what I did on my 94 V6. About a year later, after replacing a coil, the head gasket went bad!!
            2011 Camaro SS
            1986 Monte Carlo SS
              any plug will work?
                I gave you the link to sign up @ fullthrottlev6.com
                You should..these guys all own 6'ers and know what their talking about!
                  ok well was outside and i pulled one wire off the coil at a time fired her up and got spark to every coil so i called up pace and he said its prob my wires and plugs b/c 3.4s are known to eat up wires so ill give that a shot
