Front side signal lenses ?????
  • Front side signal lenses ?????
    Replacing my stock Front signal lenses with clears .
    Question ????... What is the EASYEST way to remove
    the friggin screws ??? without taking all the flip-up head light off ...
    Any info welcomed !
    **** FEAR THIS ! ***
    Any info welcomed !
    Can't help ya..... My gf's came with smoked corners and my fronts are held in by one screw from the outside.
      Thanks ... Mine are scwered in from the inside
      if I had a tiny little womens hand ,that would work !!!
      DAMN !! Nothing is ever EASY !!!
        Come on ....Any Bird people out there ,Or you all FLY the coupe !!
          There should be an access panel under the bumper that you take two 10mm bolts out and pull it down. It's still a pain in the butt to reach in there and get to the screws.
          Wade
            I will try to grab some snapshots or the panels.
            1996 Pontiac Firebird - Blue/Green Chameleon - 3.8L V6 (231ci)
            Totaled & Declared Dead: 08/07/2001 - Rebuilt & Reborn: 08/21/2002
              I really could not get any real good shots. I found some shots of the same parts on Hugger Z's turbo install thread.
              The black panels on both sides attached to the front and outside curve of the bumper. These same side panels that will need to be removed are also held up by the main air deflector, that deflects the air flow up into our radiators, with two blots on each side.
              Once those panels are removed you will have easy access to the Front Signal and Side Marker lights.
              Hope this helps.
                Wade ,David ,Thanks .... I already new that.
                looks like more than 2-3 screws tho ...
                If only my arm was a little bit skinnyier !!! GRRRRRRRRRRRRRRRR
                  It's only 2 bolts for the access panel. You don't remove the entire panel. Yes it's a pain to reach up through there!
                  Wade
                    It sure in the HELL is !!! Got the bolts out,man ....,NO room ,
                    **** it !!!! I give up for tonite ....Grrrrrrrrrrrrrrrr
                      the way i put my clears on was i took that plastic off of the headlight and squeezed my arm down there still a pain though.
                        What plastic ????? I tried squeezing my arm down there with head-lights in the open position ,and its TIGHT !!!!!
                          Got one side Done !!!!! I'll tell you what ,tho ....I took ALL the screws..
                          out & remove the WHOLE panel !! 100% easyier that way .Plenty of room to see & work ....
                            Congrats! Only took 3 days. Now get out there and do the other side.
                              Hey..Now !!! Actual work time :45 minutes ...
                              The other times was just SCOPEING it out ....
