misfire under load
  • misfire under load
    In my 3.8 i got a misfire in cyl #5 but only under load like 1/2 to wot. Im waiting for the engine to cool to check the plug but they are relitivly new. Any ideas????
    Sold!
    www.fquick.com/lozanoa11
    94 Grand Cherokee (sold)
    95 Accord(for sale)
    99 Outback (snow destroyer)
    coil pack.
    switch the coil pack for cyl 5 with another one and see if the misfire moves to another cylinder
    5th gen Camaro V6 Forums
    http://www.bowtiev6.com
      Ill try it i may have to call off from work i have to be in at 4
      Sold!
      95 Accord(for sale)
        Did you have any rich or lean codes also or just misfire on Cyl. #5?
          also if you do change the plugs go with NGK TR6 if you still plan on nitrous.
            Just misfire i can smell it when it misfires but no code. Im gunna try working on it now.
            Sold!
            95 Accord(for sale)
              Dont forget to check the wire as well.
                Ok so my testing proved inconclusive. i switched the #5 and #2 wires on the coil it still misfired but it only set a random misfire dtc. Im gunna try to set it again and go to auto zone insted of advance later. But i have to go to work soon so ill have to do it later or next week. I can drive in normal trafic w/o it misfireing so i should be good. The problem with testing every thing is there is spark at idle and when reving up. There has to be load. I wish i had a dyno lol.
                Sold!
                95 Accord(for sale)
                  sounds like a bad opti, lol
                  1996 CAMARO Z\28 M6
                    Yay I chanced it and changed the coil pack and it worked. Any time i just make an educated gusse its usaly wrong if its on my car lol.
                    Sold!
                    95 Accord(for sale)
