a couple weeks ago when i would try and put my window up, it would go half way up and stop. wait a few minutes and it would go up some more and wait again and it would go all the way up. it was doing this just once in a while but its been happening more often now. today it did it while i was trying to put the window down, it would go part way and stop, wait a minute or so and try again and it would again move a little more. any ideas? thanks for the help
power window problem
Originally posted by camarobitch02 View Postsounds like you need a new window motor
The motor is going bad.
When most electric motors start to go bad they start to produce more and more heat while they work. There is a thermal switch in the motor that cuts power when the motor gets to hot, so you don't burn out the motor.
That is what is causing the intermittent working of the motor. The motor gets hot then the switch cuts the power, motor cools down and the motor will work again. Eventually the motor will die completely, hopefully not while the window is down and it starts to rain.
Hope this helps a bit.
to be honest I dont remember, gonna say around 60 bucks just a guess tho, autozone should have one I believe theirs have warrenties or so i hear.Originally posted by turbocreeper View Postnot what i wanted to hear, but at least i know what it is now. thanks eveyone. so what are the motors running ?-Derek-
Member with Invalid Email Address
- March 25th, 2005
- 1806
- Steve Hayes
- '97 Grand Prix GTP
- Saraland AL/Lapeer MI
- Sell car and home audio
when you put the new motor in fix the ground (gm did a crappy job with the door grounds which is what actually kills the motors from what I have seen)
I got mine on ebay...autozone may be a better idea. When I went to replace it, it turns out that i was replacing the replacement. So regardless where you get it...it will probabl;y go bad again.2011 Ford Raptor SuperCrew
if you check on ls1tech there is a company that provides a rewire kit that supposedly drastically helps the windows go up faster and also the lifespan of the passenger motor. There was some reasoning behind it that the passenger window doesnt get the same amount as power and can fail easier or something like that.-Derek-
Post Whore-ess
Owns Meissen
- November 13th, 2005
- 9510
- Angie Meissen
- 2002 W68 Firebird, 3800 Series II V6
- Chesterfield, Mi
- Operator/ Receptionist
A couple of weeks ago I had to replace my driver side window.*Angie*
