was trying to search around to see what would be a good oil to use for a 383 lt1 it will be a daily driver it is built with afr heads and forged internals I have heard that royal purple is not good for the street as it is for a track car?? and have read that some use rotella ? also what would be a good weight oil.. should I run a higher weight or not ?? I do know that I am most likely going to run synthetic I do know this much..
Weight is all dependant on what you set up your bearing clearances to be depending on your application..... I wouldn't get to worried about what brand of oil your running, to much internet hype... when's the last time you heard someone say I wish I had of used Lucas instead of shell.
i run Rotella t6 because it's good oil and is cheap. i've been contemplating the switch to Amsoil though, my car only gets one oil change a year so the cost difference wouldn't be all that bad.
