Broke a arp bolt in my block
BS. ARPs are just steel. They can be drilled like any other bolt.Originally posted by slowbird780 View PostI would take it to a machine shop and almost think about having it checked out to make sure there is no damage. Easy out and arp bolt dont go in the same sentence.sigpicTurbo Charged LS1/T56
yep, arps, should be like 30ft lbs then 75ftlbs. the small ones are like 22-25.
Had a guy do the same thing to an arp crank bolt once. Had to pull engine and take it to a machine shop for that one.
If you pull the head and the bolt is sticking out it will turn out by hand. Even if its not sticking out you may be able to use a pick and rotate it. If its down in the block a reverse drill should walk it out. The bolt didnt break due to cross thread or rust that would bind the threads. You just strectched it so the part left isnt bound and should turn easy
Would have thought that you would have pulled out the threads in the aluminum block before you snapped that ARP boltWhen in doubt, Whip it out !
