Now itll prolly need the 4x4 switch or that shift module behind it. Id try the switch first. If you were close by Id say stop into the dealership here and I could check it for ya
2002 Yukon XL1500 Diagnostic Trouble Code C0323
Nothing in the service manual links it to the switch. Someone had probed the wires to the transfer case motor and they look a little corroded, but not corroded thru. Maybe that little bit would throw off the sensor and cause the light to come on? Problem with everything electrical, you can't return anything once you've bought it. I also need to take it to a dealer to get some recall work for ABS sensor?
