Found some rust, what are my options?
    basically when your having your floor done tell them to weld in some 2x2 steel or whatever that size is between both subframes. thats exactly what i was gonna do. i know 85z28kid actually cut the ears off the subframe of his 85 so he could use a thicker piece of metal.
    00 Tahoe Z71........Stock
      This happened because water got under your carpet from inside the car. There are 2 spots you can check. The T top leaking for 1. Spray the car with a garden hose with somebody in the car and see if there is a leak. 2. This option is what I am sure it is. On the driver side firewall near where the foot pedals are mounted if you pull the carpet back and really look up there you will see 2 roughly 1/2" diameter holes paired together that should have gromets/plugs in them. Usually people use these to poke wires through to the interior. If one is open or there is a hole in the gromet not filled by a wire it will leak water behind the carpet/padding causing this. My car had wet carpet for the longest time and that was the culprit. Luckily I caught it.
      Best of luck.
      99ws6 - Huron Speed Turbo - PT67
