For the past couple days I have been trying to get this 6.0 w/ TR224 cam and BBK headers to fire. First, I had a fuel issue. It wouldn't hold pressure at all once the pump was off. After many hours of searching I found a broken o-ring on the fuel pressure regulator in the tank.
With the pump on it is now roughly 57 psi, drops to 50 when it turns off and holds well. I tried to fire it on the stock LS1 tune yesterday and it would light right up on ether but only a couple cylinders would pop on just gas. That evening I went out to pick up EFIlive from a guy on MAEG. Very cool of Darius to lend it to me
I took the 98 Z28 tune and adjusted the cylinder volume to 746. I transferred over a MAF table from a 2002 Z06 because I'm using a 85mm truck MAF. I copied the VE table from a 2004 LQ4 Cargo Van just to see if it would help. Injector flow table was copied from a 2000 Z28 to match the injectors I have (12555894). EGR, AIR, and rear 02's are disabled. I don't see any reason why this wouldn't get the engine running.
I keep coming back to plugged injectors every time I try to think it over, but that's a good chunk of coin I didn't plan on spending. I'm getting a little bummed
Thoughts?
Thoughts?
I just remembered that I made and injector test rig with an old connector I had. I can bypass the fuel pump relay and fire each injector individually when I'm right next to it.
