Crankshaft repair in southeast michigan.
  • Crankshaft repair in southeast michigan.
    I live in madison heights, i'm going to pull the crank this week, anyone have reccomendations? i found a new crank with bearings for $190 shipping included. i'm leaning tword new at this point.
    So, this was the result of the noise? End up being bad main bearings?
      That or wrist pins, still gotta pull the pan and check.
        Any engine machinist can turn the crank down for you if you have a spun bearing.
          I had multiple spun bearings on my LT1 - polished the crank, new bearings, cylinder walls bored 0.040 out, etc for $1200. Was done at State Motor on Gratiot south of I696. I think it's considered Roseville over there.
            I'll call, not looking for all that on a 3.8. Lol. There's a guy at work with a 2004 2wd Silverado he bought for the cab, might be able to get a v8 and trans with wiring and the computer. 5.3 swap please.. lol.
              Automotive Machine at 14 mile and garfield
              32250 Garfield Rd, Fraser, MI 48026
              (586) 296-6501
              No longer your average SS
                LSM does some great work and they're in waterford. very reasonable too
                  Re: Crankshaft repair in southeast michigan.
                  Crankshaft craftsman is at Davison/Campeau. They do OEM work there from time/time.
                  My personal favorite is Moldex over in Redford. Last crank I had done there was $175 for a 10/10 grind and polish. Dead nuts perfect though. They are considered one of the best in the country.
                  By new... do you mean OEM new or Eagle/Scat/some other import?
                  Sent from my DROID BIONIC using Tapatalk 2
                    I was all over the net, rock auto had it for $151, Idk about brands, I can see when I get home later.
                      will need intake, injectors, throttle body, all accessories, harness is completely wrong, PCM might work with a flash, and trans tail housing will need to be swapped.
                        I've used Moldex before, was very happy with them.
                          Had a chance to drop the pan today. Spun #5.. shopping for prices tomorrow on repair vs replace. $154 on rockauto for a reground with bearings.
                            IDJ engine at 11 and hayes does an awesome job, crank was machined and polished, rod was reground. engine is in, runs great. now i'm just collecting missing and broken parts. there's a list. lol i'll post pics when I get them off my phone
