HELP! What sensor did I just break??
  • HELP! What sensor did I just break??
    When I was pulling off my passenger side exhaust manifold I broke a sensor. Its almost in line with the spark plugs and I think in between the back two. Its on an LT1. Thanks for the help!!
    Sent from my VS910 4G using Tapatalk 2
    1994 Formula - http://www.fquick.com/garages/viewvehicle.php?id=52284
    http://freepatriot.org
    Knock sensor? Got a pic?
    2002 Z28 Camaro A4
    1993 Z28 Camaro M6- SOLD
    1999 Z28 Camaro M6- SOLD
    2008 Ford Fusion SE - DD
      Re: HELP! What sensor did I just break??
      I thought knock sensor was on the intake. I could be wrong though. I just looked through every sensor on autozones website. Is it possibly the coolant temp sensor??
        Coolant temp sensor is on the drivers head unless it's different with 94+
        2002 Z28 Camaro A4
          try here : www.shbox.com
            It just hit me you have a 1994, and I have a sevice manual for the 94 LT1's/V6's. I will try and dig it out to see what sensors are over there.
              does sound like the knck sensor
                That spark plug is the 3rd one back. Sensor is right behind it.
                  Looks like a temp sensor. Weird
                  2002 Z28 Camaro A4
                    Every forum I've looked on says the coplant sensor for the gauge is below the passenger head. Can anyone verify? Also, Im almost positive its not the knock sensor. They have a very different wiring harness from what I see.
                      My coolant sensor is on the drivers head...
                      2002 Z28 Camaro A4
                        So is mine because I broke mine also when doing the headers.
                        Maybe he has an LT5?!?!?!??!?!?! =O
                        Originally posted by Yoshi94
                          Hmmm...I'm lost
                            That's REALLY weird. Do you have the coolant sensor on the driver's side, Matt? Maybe they effed up that location and put a new coolant sensor on the passenger side? I posted on LtxTech but can you take a picture of the plug? How many wires are going to it? Can you take a wider picture of the sensor?
                              Well I've always wondered what the random one wire running across my engine was. I think I have cast heads. There's no coolant sensor on the drivers side but there's a wire running across to it. So was someone just a cheap ass and put cast heads on?? Would valve covers and intake just bolt on to them??
