My clutch and brake fluids look like coffee, so I'd really like to flush them out. I hate bleeding brakes, and from what I have read, our slave cylinder is a royal PITA.
I'm looking at the Motive bleeders - 0108 or 0118. Anyone used these (or a different brand)? How'd it work? What did you use? Would you recommend it?
when i helped jeremy out with his i used the power bleeder from work as well as manually bleeding and yes it a royal PAIN in the.... i ended up leaving a small socket on it and completely forgot about the socket.
I have the 0118 and it works awesome. Very easy to do and no pedal pumping or worrying about running out of fluid. I would recommend to anyone.
And another thing.....when I gun the motor, I want the whole world to think it's coming to an end. -Homer Simpson
I have the Motive bleeder with the adapter for the brake fluid reservoir. It was simple enough to use. Use caution if you fill the bottle with fluid - I had the adapter pop off and spray brake fluid all over.
Looks like you are close to me - you can borrow it if you want.
Yeah, I can handle the brakes the old fashioned way (even though I hate those too), but the clutch just seems like a royal PITA. When I eventually replace the clutch, I'll put a tick remote bleeder in.
It should bleed quick with 2 people, the normal way.
I thought the clutch was a pain due to location and having to open/close it every pump. I just ASSumed with the powerbleeder it'd be easier as I could crack the bleeder open and just let it go until fresh fluid comes out.
I appreciate that, thanks! With all of the vehicles in the family (siblings, parents, in-laws) and me being the family mechanic, I figured it'd be a sound investment. The 0108 is the plastic cap, right? I'm looking at the slightly more expensive 0118 which uses an aluminum cap. Either way, I'll make sure I put some towels or something down and around it just in case it pops loose.
