so im doing my headgasket but i kinda got stuck and dont have the heads off yet, i need some help from someone that has done this before im in grand rapids by the ann street exit off of 131. i can get some beer or buy you something from best buy for helping lol but as for cash i kinda dont have much of that. so please help me cause this is my only car so i have no car to get to work lol. call or text me at 6167062068 if you can, (bonus if you have a floor jack and some jack stands because im trying to do this with the car sitting on the ground) thank you!
i need someone to come help me
If you weren't clear on the opposite side of the state I'd be happy to help -
someone in GR should be able to help though
aka "Plum Nuts"
- June 4th, 2008
- 5699
- Larry Meissen
- Macomb, Michigan
- Realtor
Michael what are you stuck on? To remove heads you need to remove:
1.Disconnect battery. at least the - terminal.
2.Drain the anti freeze. 2 lower bolts on water pump will drain engine block low enough without getting fluid on Opti.
3. Disconnect gas lines. (there is a disconnect tool for this.)
4.disconnect wire harness on injectors.
5. remove intake manifold
6. remove altenator.
7. remove valve covers
8. remove heads.
to install reverse order, be sure to use thread sealer on water pump bottom bolts.
check shbox.com for torque specs. (note be sure and clean threads good on head, and manifold bolts)
Shbox has proceedure to adjust valve lash.
Good luck I hope this gets you started, sorry I can't come and help. I'm to far away.sigpic
Lurker
- March 13th, 2010
- 3476
- TJ
- 1995 Chevy Camaro Z28
- Clinton Twp Michigan
- Powerline Tree Trimmer.
Same Grand Rapids is to far.Originally posted by Yoshi94Mines about an inch bigger than Kyles. I need to get one of thosesigpicOriginally posted by ryanwarby01Put it this way, if you have a money tree a LT1 is a wood chipper!
Post Whore
- November 8th, 2009
- 3000
- Tyler Porter
- 85 Z28, 91 Trans am
- Clinton Township Michigan
- student
me and a buddy would be more than willing to help if you were across state. if you need help still next week then something can probably be worked out91 Trans am, 305, Lt1 cam, 24lb injectors, headers, SLP LM2, SW chassis, massive panhard, lowered, modded TPI, Tuned, 4.10s, Lincoln locked
00 Tahoe Z71........Stock
Post Whore
- 3000
- Tyler Porter
- student
just start labeling all your connections and sensors with a marker and some tape then take off your bracketry, intake, heads etc theres only a few bolts holding each on and if yo get lost post up pics on here we can all help91 Trans am, 305, Lt1 cam, 24lb injectors, headers, SLP LM2, SW chassis, massive panhard, lowered, modded TPI, Tuned, 4.10s, Lincoln locked
Post Slut
- December 9th, 2011
- 5919
- Michael H
- Lowell, MI
- Meat Processor
I should know tomorrow if I actually get next week off (fingers crossed) so I'm still up in the air.
I almost want to load it up on the trailer and bring it back here...I like knowing that if I need a tool, it will be there. I can't stand working in someones garage then having to trek 30 miles to go grab a tool from my shop.
1994 did not use TTY head bolts
ahhh thought it was a 3.8 for some reason. do those crack coolant elbows when removing the lower intake? mine did but again i have a 3.8 so i can't be of much help. I also did the whole aluminum intake gaskets thing but again probably not necessary. i'll check the car info next time hahah.2000 Firebird A4 black hardtop
~Phil
aka "Plum Nuts"
- June 4th, 2008
- 5699
- Larry Meissen
- Macomb, Michigan
- Realtor
TTYB were phased in around 1996 or 1997 on the LT1 engines. All LS1 are ttybsigpic
Good luck, doing that in the car is not fun.-Joel
Post Whore
- 3000
- Tyler Porter
- student
even in a truck its not fun91 Trans am, 305, Lt1 cam, 24lb injectors, headers, SLP LM2, SW chassis, massive panhard, lowered, modded TPI, Tuned, 4.10s, Lincoln locked
i mean im pretty sure i have all the tools except for a torque wrench lol but i mean yea let me know cause im down to get this done and i can pay some odd amounts of money for the help lolOriginally posted by hoogiesngrinderz View PostI should know tomorrow if I actually get next week off (fingers crossed) so I'm still up in the air.
Post Slut
- 5919
- Michael H
- Lowell, MI
- Meat Processor
I am on vacation, after work tomorrow that is. Don't worry about money
